Hurly225
Jan 14, 2017Tutor
Nighthawk R7000 and Readyshare USB printer problem
My HP9800 printer worked fine for the first months on the Nighthawk AC1900 via the USB port. Then it started to give me headacke... First it would (somtimes) only print the last page of a printjob. A...
- Jan 29, 2017
In my case, resetting the r7000 fixed the bojour print problem. I'm able to print again from mac, windows, other unix systems. even while re-configuration by hand did take some time as I don't tried to safe the config prior to reseting and restoring the settings with the backuped settings file (i guessed that this will not work).
JamesGL
Jan 29, 2017NETGEAR Employee Retired
Hi Hurly225,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
multisaft
Jan 29, 2017Initiate
