Cecemel
Oct 22, 2015Aspirant
Nighthawk R7000 as access point and USB3
I just bought this amazing router and was configuring it. Because I have a router from my service provider which is hard to switch off I'll use my netgear as access point and disabled the wireless fr...
JamesGL
Oct 23, 2015NETGEAR Employee Retired
Hi Cecemel,
Welcome to Community!
I did try the configuration that you have and I was able to access both USBs connected on USB 2.0 and 3.0. The router was set as router and AP mode also. Have you performed factory reset or reload the firmware?
JamesGL
Community Team
- mondenathOct 23, 2015Prodigy
Hi Try the below firmware and see if that issue is resolved.
- CecemelOct 24, 2015Aspirant
Reuploading the firmware seems to solve the problem. Strange cause it is the same firmware as before.
I did not try the limited release firmware, it probably works also but I prefer the latest stable versions and not the beta ones.
Thanks for the help guys!
- rpoffenOct 26, 2015Virtuoso
Seems a number of problems have been fixed for some people simply by reloading the FW, especially when performing a factory reset to defaults in the process (which is highly recommended when load FW).
