Cecemel's avatar
Cecemel
Nighthawk R7000 as access point and USB3
I just bought this amazing router and was configuring it. Because I have a router from my service provider which is hard to switch off I'll use my netgear as access point and disabled the wireless fr...
  • JamesGL's avatar
    Oct 23, 2015
    Hi Cecemel,
    Welcome to Community!
    I did try the configuration that you have and I was able to access both USBs connected on USB 2.0 and 3.0. The router was set as router and AP mode also. Have you performed factory reset or reload the firmware?
    JamesGL
    Community Team
