Cecemel
Oct 22, 2015Aspirant
Nighthawk R7000 as access point and USB3
I just bought this amazing router and was configuring it. Because I have a router from my service provider which is hard to switch off I'll use my netgear as access point and disabled the wireless fr...
Cecemel
Oct 24, 2015Aspirant
Reuploading the firmware seems to solve the problem. Strange cause it is the same firmware as before.
I did not try the limited release firmware, it probably works also but I prefer the latest stable versions and not the beta ones.
Thanks for the help guys!
rpoffen
Oct 26, 2015Virtuoso
Seems a number of problems have been fixed for some people simply by reloading the FW, especially when performing a factory reset to defaults in the process (which is highly recommended when load FW).
