Koopee
Sep 07, 2022Tutor
Nighthawk R7000 attached devices list
I searched for help to a problem, where the attached devices list was nearly empty. Below is one discussion about it: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-not-showing-or-a...
Concerned-user
Sep 07, 2022Guide
Good idea!
Occasionally, a wireless device (e.g. a computer) wakes up from sleep and tries to use the IP that it had before going to sleep, but the router's DHCP already assigned that IP to a different device. Now two devices fight for the same IP!
I think those devices capable of going to sleep and prone to sticking to pre-sleep IP would better be served with a fixed IP from a range that is separate from the dynamically assigned IP range.
michaelkenward
Sep 08, 2022Guru - Experienced User
Another approach for some devices could be to fix the IP address on the device where that is possible.
That is not the same as Address Reservations on the router.
- KoopeeSep 08, 2022Tutor
michaelkenward wrote:
Concerned-user wrote:I think those devices capable of going to sleep and prone to sticking to pre-sleep IP would better be served with a fixed IP from a range that is separate from the dynamically assigned IP range.
Yes, that could also work. So far I have liked to use the method of using DHCP and then letting the DHCP server to assign the addresses, as it is relatively simple from the web interface. This way the devices (for example my laptop, printer, nas) will work in my network in the address I choose. And in another networks I almost always need not know or care about the assignments.
- michaelkenwardSep 08, 2022Guru - Experienced User
Not sure that I follow what "this way" is there, but I find that fixing the IP address on a device is good when I want to have a quick way into things like access points, printers and network attached storage (NAS) boxes, stuff with it own browser graphical user interface (GUI).
You could combine that with an Address Reservations window as also suggested.
As always, experiment is the solution, as Concerned-user suggests.
