Pops109
Feb 20, 2022Aspirant
Nighthawk R7000 blue light not connecting to Wi-Fi
All of a sudden my R7000 has all blue lights and does not connect to the internet. Unfortunately I am not at the location where the router is located. Each morning I have it set, using a 24 hour time...
- Mar 30, 2022
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
Feb 21, 2022Guru - Experienced User
Would need to get model# information on modem.
Would need to get wifi configurations on the router.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What devices do you have trying to connect?
You may need to be on site to troubleshoot this more.
