Pops109
Feb 20, 2022Aspirant
Nighthawk R7000 blue light not connecting to Wi-Fi
All of a sudden my R7000 has all blue lights and does not connect to the internet. Unfortunately I am not at the location where the router is located. Each morning I have it set, using a 24 hour time...
- Mar 30, 2022
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
Pops109
Mar 01, 2022Aspirant
Thanks. Unfortunately, I do not have anyone semi-computer literate that can help.
It just baffles me that all the lights seem to indicate everything is OK, yet nothing connects to the internet. According to my Nest thermostats it stopped communicating on Feb 14 arounf 4 am.
Mar 01, 2022Guru - Experienced User
Ya you or someone that can help you out will need to be on site.
- Pops109Mar 30, 2022Aspirant
I’m finally back at this router’s location. I reset the modem Arris model TM1602A and the R7000 router. I also changed the cable connecting the two. All lights are still white, yet still cannot connect to Wi-Fi.
Ant help would much be appreciated.
- FURRYe38Mar 30, 2022Guru - Experienced User
- Pops109Apr 03, 2022AspirantThanks. That is what I had to do. Then had to reconnect almost all smart devices. Some I had to just log into the network. Others I had to forget then reinstall. Don’t know why this happened. Hope it doesn’t do it again. If it does I think I’ll replace the router. Thanks everybody for all the assistance.
- FURRYe38Apr 04, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
