Pops109
Feb 20, 2022Aspirant
Nighthawk R7000 blue light not connecting to Wi-Fi
All of a sudden my R7000 has all blue lights and does not connect to the internet. Unfortunately I am not at the location where the router is located. Each morning I have it set, using a 24 hour time...
- Mar 30, 2022
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
Pops109
Mar 30, 2022Aspirant
I’m finally back at this router’s location. I reset the modem Arris model TM1602A and the R7000 router. I also changed the cable connecting the two. All lights are still white, yet still cannot connect to Wi-Fi.
Ant help would much be appreciated.
Mar 30, 2022Guru - Experienced User
