Pops109
Feb 20, 2022Aspirant
Nighthawk R7000 blue light not connecting to Wi-Fi
All of a sudden my R7000 has all blue lights and does not connect to the internet. Unfortunately I am not at the location where the router is located. Each morning I have it set, using a 24 hour time...
- Mar 31, 2022
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
Pops109
Apr 03, 2022Aspirant
Thanks. That is what I had to do. Then had to reconnect almost all smart devices. Some I had to just log into the network. Others I had to forget then reinstall. Don’t know why this happened. Hope it doesn’t do it again. If it does I think I’ll replace the router. Thanks everybody for all the assistance.
Apr 04, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
