RNAndrews45
Aug 15, 2022Aspirant
Nighthawk R7000 Cannot Log IN after Firmware Downgrade.
I purchased a Nighthawk R7000 in May of this year. I was constantly having issues with random dropped connections between the router & my CM700 modem. After doing some searching in the Community, I...
Aug 15, 2022Guru - Experienced User
Probably should avoid downgrading to far. I would progress back up to what you had loaded Or,
Have you tried the latest FW version?
- RNAndrews45Aug 15, 2022Aspirant
FURRYe38,
I was at v….136 before I downgraded & was still having the dropped connection issue. The main problem now is that I cannot log in to load another version of the firmware, or do anything else.
Ray Andrews
- FURRYe38Aug 16, 2022Guru - Experienced User
What does it mean "was still having the dropped connection issue"? Is this the router loosing connection with the modem or or is this a wired or wireless problem your seeing? More details are needed.
Factory reset the router and setup from scratch...I ran my R7000 with v.134 and ran great when i had it online back then:
Its on v.136 now however is being used as a wireless bridge client.
- RNAndrews45Aug 16, 2022Aspirant
As I said, the router was dropping the connection to the modem. Since I downgraded to v1.0.9.42, I have not had a single dropped connection.
My only issue at this point is not being able to log into the router administration page.
