Dlj904
Jan 06, 2022Aspirant
NightHawk R7000 Character Length
Hello, I have an IoT Edge device that is having issues connecting to the internet. The ethernet communication will not establish (led orange). When logging into the RouterAdmin, the "attached d...
- Jan 06, 2022
Host name character length wouldn't be a cause problem in the communications. Hostname seen on the routers web page is just for user viewable information seen by the router that it gets from the device. Possible that since this is a older model router, that it's limited to what the norm was at the time before your IoT device was produced and this devices uses a longer host name value.
I would contact the IoT devices Mfr for additional help and information regarding there product and getting it connected.
Jan 06, 2022Guru - Experienced User
Dlj904
Thank you for the quick reply, contacting the IoT's manufacturer was my next step.
Thanks again,
David
