KJFOG
Jul 25, 2019Initiate
Nighthawk R7000 Connection Issues
I want to start with a little backstory...I first purchased this Nighthawk router in August of 2017 and used it for approximately 20 months with no issues whatsoever. It would stay connected/online f...
DomLC
Dec 16, 2019Guide
Will be useless retype the first post.
I have the same issue, I need to unplug it every 18-24 hours!
My firmware version is:
V1.0.10.90_10.2.90
Any suggestestions ?
Thanks
V1.0.10.90_10.2.90
Thanks
antinode
Dec 16, 2019Guru
So, when you start your own thread for your own problem, include a
link to any other relevant thread(s) which you might have found. Also,
copy+paste is your friend,
> V1.0.10.90_10.2.90
Other than those already offered here? No.
V1.0.10.90_10.2.90 was withdrawn within about one day of its
publication. V1.0.9.88_10.2.88 has been inciting complaints since its
publication.
A quick Web or forum search for either might find any number of
complaints. The current consensus seems to be that V1.0.9.42_10.2.44 is
a better bet.
