SithLord2K
Nov 18, 2021Aspirant
Nighthawk R7000 Devices Missing From Attached Devices
After the latest firmware update 1.0.11.128, I had an issue where the attached devices list was not showing all of the devices connected. I found instrustions here to factory reset and manually set i...
Miked2
Nov 18, 2021Apprentice
I have the same issue. It says Attached Devices = 20, yet the list has 5 in it. After a full reset it worked for a couple weeks, now broken again! Too hard to keep reseting the router!
SithLord2K
Mine is at least accurate, it says 4 devices connected, it's just missing the other 7 to 8 devices that are usually connected
