SithLord2K
Nov 18, 2021Aspirant
Nighthawk R7000 Devices Missing From Attached Devices
After the latest firmware update 1.0.11.128, I had an issue where the attached devices list was not showing all of the devices connected. I found instrustions here to factory reset and manually set i...
Nov 18, 2021Guru - Experienced User
If you guys are having problems on v128 and have done resets and the problem still appears, I would revert back to a prior version of FW that worked for you.
Miked2
Nov 18, 2021Apprentice
Yea - I could keep reinstalling old FW to try to get stuff to work, and reseting the modem and re-entering all my settings. But, since Netgear can't see to make products that just work, perhaps a new router is a better way to go. My time is valuable. Any thoughts on better similar products?
- FURRYe38Nov 18, 2021Guru - Experienced User
One can load up 3rd party FW and see if that works better.
Do online searches for router reviews if your looking for something different.Good Luck.
