SithLord2K
Nov 18, 2021Aspirant
Nighthawk R7000 Devices Missing From Attached Devices
After the latest firmware update 1.0.11.128, I had an issue where the attached devices list was not showing all of the devices connected. I found instrustions here to factory reset and manually set i...
Nov 18, 2021Guru - Experienced User
If you guys are having problems on v128 and have done resets and the problem still appears, I would revert back to a prior version of FW that worked for you.
SithLord2K
I'm going to give that a try tonight, unfortunately working from home and online schooling for my daughter limits what I can do during the day.
- FURRYe38Nov 18, 2021Guru - Experienced User
đ
