swilson317
Nov 16, 2023Apprentice
Nighthawk R7000 Dropping WiFi
I've seen other posts with this same subject line, but nothing more recent than 2020. This is really a long-term, frustrating situation. I suspect it was introduced with a firmware update a while ago...
Nov 17, 2023Guru - Experienced User
That router is a decade old. It was released on 2013.
Any device I have that is a decade old and worked that long doesn't leave a 'bad taste in my mouth".
It leaves me impressed that it was still applicable for that long.
but you do you.
And like michaelkenward says, a bit more details help to determine if its a router issue, device issue, or just a firmware issue.
The newer firmware haven't had nearly the reports the old 1.0.9.** versions did.
- swilson317Nov 18, 2023Apprentice
Thanks for the replies. I gave up and decided to replace it with a non-Netgear product. WOW! What a difference! Wired and WiFi speeds are significantly faster and haven't had any drops in the last couple of days. Turns out a friend with the same model had the same experience. I guess it was just showing its age. I was done screwing around with it. It should just work...and it was for the beginning of its life. 🙂
- plemansNov 18, 2023Guru - Experienced UserGlad the new one is great!
- michaelkenwardNov 19, 2023Guru - Experienced User
You have probably jumped several generations of technology in the new hardware. The original R7000, never the most capable kid on the block, predates the growing availability of Internet services approach 1 Gbps. let alone the widespread plague of those Internet of Things (IoT) gadgets
It won't just be the technical features that are better, thanks to improved chipsets, you should also have a device that is more user friendly to control.
With luck your new system won't try to sell you add-on services that get you sucked into its clutches for life.
By the way, even a pensioned off R7000 can have its uses. If your new setup lacks support for USB, your old router can work in AP mode and add USB storage and printing to your network. No need to use the wifi. Just turn it off
