swilson317
Nov 16, 2023Apprentice
Nighthawk R7000 Dropping WiFi
I've seen other posts with this same subject line, but nothing more recent than 2020. This is really a long-term, frustrating situation. I suspect it was introduced with a firmware update a while ago...
swilson317
Nov 18, 2023Apprentice
Thanks for the replies. I gave up and decided to replace it with a non-Netgear product. WOW! What a difference! Wired and WiFi speeds are significantly faster and haven't had any drops in the last couple of days. Turns out a friend with the same model had the same experience. I guess it was just showing its age. I was done screwing around with it. It should just work...and it was for the beginning of its life. 🙂
Nov 18, 2023Guru - Experienced User
Glad the new one is great!
