tmiprov's avatar
tmiprov
Nighthawk R7000...Ethernet connections works fine, but Speedtest.net test on Ethernet port fails
  • myersw's avatar
    myersw
    Oct 11, 2019
    What you download is a zip file. Did you expand it? The .chk file is inside the zip file.
