RxRot
Nov 09, 2021Aspirant
Nighthawk R7000 Factory Reset Itself - I lost my Guest Network and the new App is too basic/useless
What happened to my router? This R7000 has been bullet-proof for years and now it's a mess. I came in today to find it had factory reset itself. All my Guest network settings were gone. I tried t...
Nov 09, 2021Guru - Experienced User
Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed or something like this happens, you can just reload and go.
- RxRotNov 10, 2021Aspirant
I am on the newest firmware per the app - 1.0.11.106.
There is no button for the Guest network in the app, but it is in the online directions posted by Netgear. I am at a loss as to why I don't have the option. I do have the newest app version.
The rest of the components in the system should not matter. All the same equipment was functioning with a guest network for years and now it will not. I need to get into the settings to fix it. PLEASE HELP!
- FURRYe38Nov 10, 2021Guru - Experienced User
To find more and detailed information, please log in to the routers web page at 192.168.1.1 using a PC and web browser.
You'll find guest network options there.
That is precisely my point...it will not log in via routerlogin.net or 192.168.1.1 on my computer. I was hard wired and had wifi turned off and it still will not connect. Is the router ready for recycling?
- Portwey84Nov 10, 2021Virtuoso
RxRot wrote:I am on the newest firmware per the app - 1.0.11.106.
RxRot I'm afraid you're not on the newest firmware, you're 4 firmware updates behind. The latest firmware for this model, is:
R7000 Firmware Version 1.0.11.128 | Answer | NETGEAR Support
In essence, don't believe what either your router browser GUI or Nighthawk App tell you because even I'm one firmare behind and both my router GUI and App tell me I'm up to date.
This router is getting very long in the tooth now and if you've had it for years, it might be worth upgrading.
