WilsonY
Mar 02, 2022Tutor
Nighthawk R7000 firmware update with APP & Connected Question
So I had upgraded my Comcast internet speed to 800mbs about a year ago and upgraded my modem and router to be able to run at Gig speed. For the past year since the upgrade, my internet speed have o...
Mar 02, 2022Guru - Experienced User
a couple things.
1. you don't need ethernet to update manual. its recommended but you can do it over wifi.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
2. that router won't hit gigabit speeds over wifi. It will over wired. Here's some realistic speedtesting info from smallnetbuilder (reputable site) on how that router performed https://www.smallnetbuilder.com/wireless/wireless-reviews/32239-ac1900-first-look-netgear-r7000-a-asus-rt-ac68u
3. what wired speeds are you getting? (hint, the built in speedtest isn't accurate).
4. how are you testing those speeds?
