cwang2018
Jan 21, 2021Initiate
Nighthawk R7000 firmware V1.0.11.116_10.2.100 connection issues.
Upgrade firmware recently to V1.0.11.116_10.2.100. The wifi would drop to my various devices through out the day, it would get serious enough where I would need to power off and power on the router. ...
Jan 21, 2021Guru - Experienced User
If it only happened after the firmware change, try factory resetting the router and reinstall it (not from backup).
If that doesn't help, the agreed upon stable version for the r7000 is 1.0.9.42. this tends to work the best on the r7000
