cwang2018
Jan 21, 2021Initiate
Nighthawk R7000 firmware V1.0.11.116_10.2.100 connection issues.
Upgrade firmware recently to V1.0.11.116_10.2.100. The wifi would drop to my various devices through out the day, it would get serious enough where I would need to power off and power on the router. ...
RandyBinCA
Feb 10, 2021Aspirant
Same issue here.. Updated yesterday and today I'm lossing the anything connected to 5G..
cwang2018
Feb 10, 2021Initiate
netgear support recommend me downgrad to Firmware Version V1.0.11.100_10.2.100. I will report back how it goes.
- RandyBinCAFeb 11, 2021Aspirant
I did as suggested yesterday.. Did not go well, lasted about an hour and then dropped all the connections.. Which if I remember right is why I got off that version 1.0.9.42 in the first place. I didnt want to because it was the last version that supported Apple's Time Machine. So a factory reset again and loaded V1.0.11.116_10.2.100 again, today its seems to be dropping only devices connected to 5G.. Curious to see if V1.0.11.116_10.2.100 fixes your issue..
- Cabdi227Mar 27, 2021Aspirant
