cwang2018
Jan 21, 2021Initiate
Nighthawk R7000 firmware V1.0.11.116_10.2.100 connection issues.
Upgrade firmware recently to V1.0.11.116_10.2.100. The wifi would drop to my various devices through out the day, it would get serious enough where I would need to power off and power on the router. ...
cwang2018
Feb 10, 2021Initiate
netgear support recommend me downgrad to Firmware Version V1.0.11.100_10.2.100. I will report back how it goes.
RandyBinCA
Feb 11, 2021Aspirant
I did as suggested yesterday.. Did not go well, lasted about an hour and then dropped all the connections.. Which if I remember right is why I got off that version 1.0.9.42 in the first place. I didnt want to because it was the last version that supported Apple's Time Machine. So a factory reset again and loaded V1.0.11.116_10.2.100 again, today its seems to be dropping only devices connected to 5G.. Curious to see if V1.0.11.116_10.2.100 fixes your issue..
- Cabdi227Mar 27, 2021Aspirant
