Dsrtplyr's avatar
May 21, 2018
Nighthawk R7000, Firmware V1.0.9.26_10.2.31 - COMPLETE CRAP!!! USELESS GARBAGE!!!!
I will NEVER buy a Netgear product again!  Their equipment is crap, their customer support people are USELESS!!!  Their support staff are idiots who waste more damned time with their niceties and scr...
  • IrvSp's avatar
    IrvSp
    Jun 02, 2018
    Dsrtplyr, your litany of problems is unreal. Way too many to be easily understood. Something is quite different with your LAN topology and operation.
    DLNA not building another database after you deleted it? I'm wondering if you do have a bad hard drive like I did? Using the same port of not? USB drive powered or portable? Any of these could present a problem, and could a failing power supply to the router or a lose connection even? Something is not right with your setup?
    Does the speed lose happen on all bands and wired connections? What are you basing this on?
    Printer, you had Public/Private problems before and now it is worse? Does the printer have the lastest firmware? Do you have a Security mismatch? What happens if that SSID didn't have any security, same thing?
    I've seen on a friends laptop very low connection speed (only one on the SSID) and thought the router was broken (also a NG). Turn out the wrong security was used for the Laptop. Picked the right one and the problem went away. What security do you have on each SSID?
    My BEST suggestion to you, got to the Genie (on a browser) and log into the router. On the Advanced tab on the top on the left side select ADMINISTRATION, BACKUP SETTINGS tab, and then the last line's button, Revert to factory default settings, and presss ERASE. EVERYTHING will be gone and you MUST start fresh again. Either take screenshots of your settings or write them down. DO NOT restore a file with them, it could just put you right back where you are now with problems.
