BlueFox1971
Nov 29, 2018Aspirant
Nighthawk R7000 Firmware V1.0.9.42_10.2.44 Update Failure - White Flashing Power Light
I decided to update the firmware on my R7000 WiFi Router this afternoon while the family was out and since it had been running a little sluggish.
I stupidly did this through the Nighthawk App on my...
- Nov 29, 2018
> [...] I have also tried the TFTP2 method [...]
That's too terse a description of a multi-step procedure with
multiple variables. And there's probably no real need to download
any program. See, for example:
https://community.netgear.com/t5/x/x/m-p/1622096
shamarin
Nov 29, 2018Virtuoso
A newer FW is available 1.0.9.58
- BlueFox1971Nov 29, 2018Aspirant
I had noticed that, but when I follow the link provided by Netgear for 1.0.9.58 I get an error and so I went to the next best one to download to try and install via the TFTP2 method which still did not work.
I am currently having to use WiFi from my phone to the computer to get the downloads onto it to try and update the router.
- shamarinNov 29, 2018Virtuoso
It should be available via router GUI updater.
I can't get into the router GUI updater as the router is not responding.
I'm not sure if I'm doing something wrong, but I am trying to access it via http://192.168.1.1/ or is that not the way to the GUI?
