Critts
Oct 04, 2017Tutor
Nighthawk R7000 flashing white power led
I made the mistake of updating my firmware and now my router is unusable. My router is a nighthawk R7000. I am currently running windows 10 on my desktop. I logged into the router and click on update...
- Oct 06, 2017
I found a step by step forum that worked for me. I had tried tftp on my computer as well as tftp2 that was recommended by another forum. This other forum recommended using tftp -i on however what I didn't know was that you have to first enable/install software in windows for it to work. The forum I mention is "https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-softbricked/td-p/414034". Thank you for helping me fix the firmware problem.
Critts
Oct 05, 2017Tutor
Thank you for giving me another option sadly though, it didn't work. I followed your instructions for resetting it. This time the reset switch did seem to restart the router. When i let up on the switch it seems to boot up then start flashing the white power led at me like before. The article you linked is the one I tried. Every attempt to run the tftp2 I just get the error "unable to get responses from the server." I can ping the router using cmd. I have tried the default password as well as my current password.
antinode
Oct 05, 2017Guru
> [...] I have tried Netgears "support" page that shows how to install
> new firmware. It only gives support for windows xp and 7. [...]
Which 'Netgears "support" page' was that? The differences between
Windows 7 and Windows 10 are not great enough for that to matter much in
a case like this.
> [...] but tftp-i is not a command for the cmd.
Did you leave out a space? "tftp -i", not "tftp-i"? On most
command-line interfaces, space characters are used to separate commands,
options, parameters, and so on. And "-i" looks like an option.
> Another page recommended that I use tftp2 however that did not help
> either.
Which "Another page" was that?
"did not help" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions with their actual results (error messages, ...)
can be more helpful than vague descriptions or interpretations.
> [...] I have tried the default password as well as my current
> password.
If you've done the full ("factory") reset, then your "current
password" is now your former password, and the default password is now
the real password.
- William10aOct 05, 2017Master
You has some very good videos on how tffp the netgear r7000 router.
