Critts
Oct 05, 2017Tutor
Nighthawk R7000 flashing white power led
I made the mistake of updating my firmware and now my router is unusable. My router is a nighthawk R7000. I am currently running windows 10 on my desktop. I logged into the router and click on update...
- Oct 06, 2017
I found a step by step forum that worked for me. I had tried tftp on my computer as well as tftp2 that was recommended by another forum. This other forum recommended using tftp -i on however what I didn't know was that you have to first enable/install software in windows for it to work. The forum I mention is "https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-softbricked/td-p/414034". Thank you for helping me fix the firmware problem.
antinode
Oct 06, 2017Guru
> [...] I have tried Netgears "support" page that shows how to install
> new firmware. It only gives support for windows xp and 7. [...]
Which 'Netgears "support" page' was that? The differences between
Windows 7 and Windows 10 are not great enough for that to matter much in
a case like this.
> [...] but tftp-i is not a command for the cmd.
Did you leave out a space? "tftp -i", not "tftp-i"? On most
command-line interfaces, space characters are used to separate commands,
options, parameters, and so on. And "-i" looks like an option.
> Another page recommended that I use tftp2 however that did not help
> either.
Which "Another page" was that?
"did not help" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions with their actual results (error messages, ...)
can be more helpful than vague descriptions or interpretations.
> [...] I have tried the default password as well as my current
> password.
If you've done the full ("factory") reset, then your "current
password" is now your former password, and the default password is now
the real password.
William10a
Oct 06, 2017Master
You has some very good videos on how tffp the netgear r7000 router.
