Critts
Oct 05, 2017Tutor
Nighthawk R7000 flashing white power led
I made the mistake of updating my firmware and now my router is unusable. My router is a nighthawk R7000. I am currently running windows 10 on my desktop. I logged into the router and click on update...
- Oct 06, 2017
I found a step by step forum that worked for me. I had tried tftp on my computer as well as tftp2 that was recommended by another forum. This other forum recommended using tftp -i on however what I didn't know was that you have to first enable/install software in windows for it to work. The forum I mention is "https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-softbricked/td-p/414034". Thank you for helping me fix the firmware problem.
Critts
Oct 06, 2017Tutor
