lexigreer
Nov 06, 2017Aspirant
Nighthawk R7000 I am unable to get the password no matter what I try.
My Landlord left the router here for me to use. I have a VOIP phone and need to get into it to get a static IP address and Provision my phone to work properly. The factory login admin/password does n...
- Nov 13, 2017
I actually ended up calling Netgear and talking to them. You have to hold down the reset button for 1 full min in order for it to actually reset you can leave everything plugged in. As soon as I did that I was able to get in and set everything up as needed. Contacted my internet provider to get the static IP address and Volia! My phone works perfectly and I can now access the router set up.
Thanks again!!
lexigreer
Nov 09, 2017Aspirant
I tried to reset it and the admin/password still does not work lol I'm ready to pull my hair out. Thank you!
michaelkenward
Nov 09, 2017Guru - Experienced User
Do not confuse wifi access, and passwords, with connecting to the router.
References to your phone suggest that you are using wifi.
First connect to the wifi and then the router's browser interface.
Default wifi SSID and passwords will be on the bottom/back of the router.
- lexigreerNov 09, 2017Aspirant
Thank you!! When I say phone I mean my VOIP phone that is directly connected to my router. I have downloaded the Netgear Genie and rest the router again and the factory login admin/password still does not work. The factory set wifi password works, no problem there.
I just need to get into the router settings the configure it and then contact my internet company for a static IP address in order to get my VIOP phone to work, I can recieve incomming calls fine but when I dial out it will ring and as soon as anyone picks up it drops the call. Could this be something else?
Now when trying to access the genie it just spins and spins forever then tells me the router response timed out...............should I just throw it out the window?
- michaelkenwardNov 09, 2017Guru - Experienced User
I still don't know if you are using wifi to access the router or if you have a wired (LAN) connection.
If wifi, then what are you using to access the R7000 and how do you do it?
For example, if you are using a web browser, what address are you using in the browser?
