mntolia
Mar 18, 2017Guide
Nighthawk R7000 is bricked and keeps restarting every few mins
Hi, I bought a nighthawk R7000 router. It was running smoothly for a few months. I downloaded and tried to update the firmware but then it doesn't turn ON and keeps showing that Amber Light. It also...
- Mar 19, 2017
You can try the official instructions from Netgear (link).
If that doesn't work, then you may need to use a serial cable to recover. This requires you to open the router to access the serial port with a special cable that you can purchase. The cable is reasonably inexpensive (around $10). There are lots of instructions for recovering routers on the Internet. Here's one for the R7000 (link).
aalexandrebeta
Mar 18, 2017Master
mntolia
Mar 18, 2017Guide
Thanks.
Edit: It restarts every 30 seconds precisely.
- aalexandrebetaMar 18, 2017Master
Handy for cooking sessions!!
Just kidding!
