robkorver
Apr 12, 2023Aspirant
Nighthawk R7000 keeps resetting to factory defaults
I have 2 Nighthawk R7000's that both keep resetting to factory defaults after a power failure. Nothing to do with surges, sometimes when I switch it off and on with the power button it also resets to...
Apr 12, 2023Guru - Experienced User
IF you have manually loaded FW on these units using a wired PC and web browser and afterwards, powered OFF for 1 minute then back ON, then after they are ready, performed a factory reset:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
and setup from scratch and then continue to exhibit this, I would presume these unit are faulty and needs replacing.
robkorver
Thank you for your answer! I did exactly once what you describe. It took a long time to set it up manually, I use a lot of NAT's etc... After this procedure (which I read before) it didn't solve the issue and after another power outage the unit reset to factory default again. These R7000's are not under warranty anymore and I read the same issue with similar wifi routers of Netgear not only the R7000. These R7000 worked Ok for about 5-6 years but now they're useless, I'll move to another brand.
- FURRYe38Apr 12, 2023Guru - Experienced User
Good Luck.
- plemansApr 12, 2023Guru - Experienced User
What actual firmware version are you on for them?
- robkorverApr 12, 2023Aspirant
the latest, V1.0.11.136_10.2.120 on both. But the previous version had the exact same issue, I just recently updated and hoped it would solve the issue but no luck
- michaelkenwardApr 12, 2023Guru - Experienced User
What happens if you get these things set up as needed and then save the settings?
Can you reload the backup and get back in business?
