angrycandy
Jan 25, 2021Follower
Nighthawk R7000, LAN desktop not connecting to gateway
I'm setting up this router for the first time in a new apartment. When I plug my router into the modem and my desktop into the router, Windows says "unidentified network, no internet," though when my...
michaelkenward
Jan 25, 2021Guru - Experienced User
angrycandy wrote:
I'm setting up this router for the first time in a new apartment. When I plug my router into the modem and my desktop into the router, Windows says "unidentified network, no internet," though when my desktop is plugged directly into the modem, the internet works fine. The power light on the router is solid red, the internet light is on, and so is the ethernet light for the port connected to my desktop.
That's a standard Windows issue that has nothing to do with your router. It sees a new network and tries to protect you from it. A good start is with the Windows Network troubleshooter.
One thought is that you could tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
I'm told that this is rubbish advice. But it has worked for me and others in the same boat.
angrycandy wrote:
I've tried resetting the modem and factory resetting the router several times, and nothing has changed. I've tried several different devices and ethernet cables too.
What is that modem?
