GearUser1042
Apr 21, 2022Aspirant
Nighthawk R7000 loses connection
Dear community, We are experiencing a drop in internet connection at least once a day. I can not find the reason why this drop is happening. The only thing that helps is resetting the R7000. After ...
michaelkenward
Apr 22, 2022Guru - Experienced User
GearUser1042 wrote:
This is the setup:
1. A modem from the ISP is set in bridge mode (DHCP turned off) and is the entry point of the internet
What is this ISP modem?
"DHCP turned off" is not the same as bridge mode.
- GearUser1042Apr 22, 2022Aspirant
Hi michaelkenward,
Thanks a lot for your response.
The ISP is the modem from my Internet Service Provider. So basically, where the internet comes in.The modem is a router at the same time. But I do not want to use the router functionalities from this modem due to poor performance. Therefore, the service provider offers to set the modem in bridge mode. Bridge mode with this service provider means that the DHCP server is turned off automatically. Please see below a URL in Dutch from the service provider.
https://www.ziggo.nl/klantenservice/internet-wifi/bridge-modusI hope this clarifies. I am looking forward to hearing some suggestions that I can have a closer look at. Thanks!
- michaelkenwardApr 22, 2022Guru - Experienced User
So, it isn't that DHCP is turned off, but that it is in bridge mode, which disables DHCP.
I asked because it is possible to disable DHCP on a router without putting it into bridge mode. There are other router features that can remain active.
Yes, you are correct. Because the modem is in Bridge mode, DHCP is automatically disabled. I use the Nighthawk as a DHCP server.
If you know what is causing the internet drop-off, let me know.
