qzkhtw's avatar
qzkhtw
Nighthawk R7000 loses WIFI connections during backup process
I have a wintel laptop directly attached, via Cat5, to my Nighthawk router.  I also have a Cisco IP Phone #7965 attached, via Cat5.  There is a 3tb Seagate USB drive attached to the 3.0 port, using R...
  • qzkhtw's avatar
    qzkhtw
    Oct 07, 2015
    I did perform a factory restore using the current firmware (V1.0.4.30_1.1.67).  I still experienced the connection loss, so I down graded the firmware to V1.0.4.28_1.1.64.  I haven't noticed any connection loss, as of yet, but I also unplugged the Seagate drive from the USB 3.0.
    I'll attached the drive, cycle the router, and run a backup this evening.
    I've had connection related issues, usually associated with backing up large files to the network drive, for many months - using different versions of firmware.  When the issue happened, I just reset the router.  This is the first time I downgraded firmware.  I also had legacy Cat 5 cables that I recently swapped out with Cat 6a.
