qzkhtw
Oct 01, 2015Aspirant
Nighthawk R7000 loses WIFI connections during backup process
I have a wintel laptop directly attached, via Cat5, to my Nighthawk router. I also have a Cisco IP Phone #7965 attached, via Cat5. There is a 3tb Seagate USB drive attached to the 3.0 port, using R...
- Oct 07, 2015
I did perform a factory restore using the current firmware (V1.0.4.30_1.1.67). I still experienced the connection loss, so I down graded the firmware to V1.0.4.28_1.1.64. I haven't noticed any connection loss, as of yet, but I also unplugged the Seagate drive from the USB 3.0.
I'll attached the drive, cycle the router, and run a backup this evening.
I've had connection related issues, usually associated with backing up large files to the network drive, for many months - using different versions of firmware. When the issue happened, I just reset the router. This is the first time I downgraded firmware. I also had legacy Cat 5 cables that I recently swapped out with Cat 6a.
JamesGL
Oct 07, 2015NETGEAR Employee Retired
Hi qzkhtw,
Welcome to Community!
Have you performed a factory reset to your router? Did it work before with other firmwares?
JamesGL
Community Team
qzkhtw
Oct 07, 2015Aspirant
- JamesGLOct 09, 2015NETGEAR Employee Retired
- qzkhtwOct 12, 2015Aspirant
The firmware downgrade corrected my connection issues. I was able to backup ~125tb to both the local usb drive as well as the network drive, without loosing any connections. I did notice in the log, that the network drive disconnected, then reconnected about 10 minutes later. This was early in the morning and I didnt see anything that would have caused this (no backups were running). Perhaps this is normal behavior and I'm just now noticing it.
- JamesGLOct 12, 2015NETGEAR Employee Retired
You can try this firmware as well.
JamesGL
Community Team
