stevieflower
Feb 05, 2020Tutor
Nighthawk R7000 needs frequent reboots
My Nighthawk R7000 -AC1900 router needs to be frequently rebooted. This just started about 2 weeks ago. It was working perfectly. We bought it less than 6 months ago. It might connect to the intere...
- Jun 08, 2021
Running: V1.0.11.116_10.2.100
First, Sorry that this got to long. Please feel free to ignore and not read the whole thing.
I just wanted to relay my experience and how I have the router behaving very well now.
________________________________________________________________________
So I have been plagued with this stupid problem to the point of where I started to look for a different router.
But I'm holding off because I seem to have the router cooperating a lot more by doing a couple of things every day or two, that seem to keep it operating just fine now.
I haven't HAD TO reboot it in a couple of weeks or so! THAT'S PROGRESS!
So first, let me say, I think that ONE of the major problems with this router and its firmware versions, is that it does not handle massive traffic very well, EVEN THOUGHT IT'S A 'GAMING" router.
For my gaming server (which I no longer run or bother with), I had a bunch of ports forwarded to my server's static IP.
Being that these particular ports are well known for the environment I was running, there were constant attacks by :Russia
China
and a few other countries where reporting bad actors was useless.
At one point, so that I wouldn't have to totally remove all the redirects, I just put in a fake IP that went no where on my network, so that any attacks to any of those port ranges would just go to that fake IP.
I also set up huge ranges to redirect attacks to there as well...
THAT WAS A MISTAKE!!!! That's because the router would STILL try to process the requests rather than just ignoring them.
I would notice my entire network starting to grind to a halt , so I'd check the logs and see hundreds of attacks, trying to get into my server. From Remote Desktop attempts to DoS attacks to port hammering, etc.
I'd have to reboot my router and the modem that connects me to my ISP.
Doing so would get me a new external IP as well as clear the cache in the router.
I would also clear the logs, apply and refresh to clean that up.
Sometimes, I couldn't even log into the router and I would have to power cycle it.
I still have some ports open for my security cameras so that I can access away from home.
But with that, I still had the router choke up every couple of days.
I finally decided to REMOVE ALL PORT FORWARDING except for my cameras. Those are vital.
Well that settled things down A LOT!
However, then I would see those same countries trying to access my cameras.
So for those, I tightened up their passwords. At least it won't be easy for those BOZOS to monitor my cams.
But still, the router was not stable. Sure, it was a lot more stable, but I still had to reboot every few days!
To troubleshoot this problem, I have a Command Prompt constantly pinning google.com -t.
When the router would start to get wonky, I'd see packets dropping from the ping.... INTERESTING.
Sure enough, in the logs, I would see attacks, including still, DoS attacks.
But something still didn't seem right.
So then, I added another command prompt window and constantly piinged the router's internal IP.
I wanted to see if pinging outside my network to the internet would fail, but internal pinging was ok.
Sometimes, this was the case ,but other times, more often, when one would start dropping packets, so would the other! HMMMMM
So then, I powered up my laboratory computer, which sits right beside the router and is wired directly into it. This computer does NOT go through anything else, no switches, nothing.
I also ran a command prompt, pinging the router as well.
Now, with 3 pings being monitored, I could get a better visual on where the breakdown is happening.
So now here is where I found what is in fact one of the biggest problems with this dammed router.
THE LOGS! Yes! THE FREAK'N LOGS!
What I discovered that as the log file increased in size, is when the router would start to get wonky!
I could see dropped packets on the external ping, then drops on this machine that pings the router (but it goes through switches). But sometimes, the Lab computer wasn't seeing drops!
But then, I'd start seeing drops on the connected Lab computer.
I started monitoring the logs closer but nothing unexpected was seen.
I did notice, however, that the drops were right around the time that the attackers were trying to get connected to the ports that I did have open.
But at other times, even with that, there was no issues.
I got into the habit of clearing the logs so I would get a clear picture each time.
It's then that I noticed, when I cleared the logs, within seconds, the dropping of packets stopped and the router settled back down!
I've seen this kind of file corruption in older software, but I would have thought that in 2020/2021 there would be much better routines to keep caching in check.
So, very long story short,- remove any port forwarding that you do not NEED
- do not set up huge ranges of ports to forward to a fake IP (if you don't forward ports, the router will just ignore requests to ports not listed)
- clear the log daily (at least to confirm if this solves the problem).
bcjacobson
Jan 12, 2021Tutor
I have a newer router also and this just started happening a few days ago. I have to reboot my router every morning now. I have read all the posts here and maybe give the suggestions a try... or just wait until they release a new version that may fix it.
onimic70
Jan 12, 2021Guide
Roll back the firmware to this version - V1.0.9.42_10.2.44
Once I did that I haven't had an issue. Sucks as there are probably security holes as this is an older firmware.
Here's what I that fixed my issue.
1.) Downloaded the firmware and had it saved on my desktop so I did the firmware push via a network cable vs. wireless.
2.) Factory reset the router to wipe all settings out.
3.) Once logged into the newly reset router, did the manual firmware update that I downloaded above.
4.) Router rebooted.
5.) Setup my wifi network and anything else( I have a NAS and some remote stuff that I had to redo) and then went and added all my devices to the WIFI and all has been good since. (Did this over the summer so its been over 6 months solid).
Good luck and Netgear sucks for not doing something better to resolve this issue...
- Jms2829Jun 13, 2021AspirantHow do you download old firmware?
- michaelkenwardJun 13, 2021Guru - Experienced User
See above.
- BlondieSLJun 13, 2021GuideJust enter your router's model number (make sure it correct) and go to the support page. You should be able to see archived and/or older versions listed there. I was able to download several older version to test. Then, just unzip the file, save the firmware file somewhere easy to get to, then update the router by pathing to where you have the update. I'd suggest that before doing that, go into the area where you can save your configuration. I do that, but I also do page snapshots and keep them in a spread sheet. For my port forwarding I can highlight everything and just paste it into a spread sheet.
