jabrace's avatar
jabrace
Follower
May 04, 2021
Nighthawk R7000 Networking Switch Won't work + 5G connection issues
Hi -
I am trying to use a new switch in my setup, but it does not work for any of my wired devices trying to use the switch. TP-LINK SH1008P 4 GB port switch. I connect to my local internet but get no outside connection. When I run a diagnostic check, it says check your router. I restarted it several times, but it does not work.
Any settings / configurations on my router I should update? Not when I plug one of my end computers into the switch, they cannot connect to the internet any more either.
Thanks,
James
1 Reply
  • > I am trying to use a new switch in my setup, but it does not work for
    > port switch. [...]
       So, you're having problems with a TP-Link switch, and you came to a
    Netgear forum to ask about them?  An SG1008P seems to exist.
    > [...] When I run a diagnostic check, [...]
       What kind of "diagnostic check"?  On _what_?
    > [...] it says check your router. [...]
       Perhaps because that (unspecified) device can't talk to any router.
    > Any settings / configurations on my router I should update? [...]
       No.
       Huh?  "Not"?  What are "end computers"?
       If you connect a computer directly to an R7000 LAN Ethernet port, it
    works as expected?  And if you connect a computer directly to a port on
    the "SH1008P" is fails (in some mysterious way)?  And you blame the
    R7000 for that?
       What, exactly, did you connect to what, exactly? (Hint: If a device
    has different types of ports, then "connected to device" is not enough
    detail.)
       Have you checked/swapped any Ethernet cables?  Do your computers get
    valid IP addresses?  Do they admit to having a good physical link on
    their Ethernet interfaces?
       Are there LED indicators on these devices?  What do they indicate?
    For the R7000:
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    LED descriptions and "Troubleshoot".
       For information on the TP-Link switch, you might take an
    actual/accurate model number to "tp-link.com".
