PenGn
Nov 21, 2021Initiate
Nighthawk r7000 not showing as a lan device on gateway
I have a ATT DSL Gateway Model No 7550. I have contacted them already. No use. When I first bought my R7000, it worked flawlessly out of the box. Connectivity was great, no issues. Well after a while...
kingtom
Nov 21, 2021Tutor
PenGn wrote:I have a ATT DSL Gateway Model No 7550. I have contacted them already. No use. When I first bought my R7000, it worked flawlessly out of the box. Connectivity was great, no issues. Well after a while, the internet connection would randomly drop and you could not access the internet for a bit. Well now the gateway does not want to recognize that the r7000 is connected via ethernet. I have tried most things under the sun and would appreciate any help. I can give more technical information as needed.
I also faced the issue but I restarted then it got fixed.
