Moongidget's avatar
Moongidget
Nighthawk R7000 Offline, Needs Restarting DAILY!
Very frustrating, but ever since firmware update 1.0.11.126 in July 2021, this router goes offline pretty much daily.  I can restart it using the app, and that process restores functionality, but in ...
  • Moongidget's avatar
    Moongidget
    Oct 15, 2021
    I also just called the internet utility and they suggested doing a factory reset.  I'll keep you posted if anything changes.
