Moongidget
Oct 14, 2021Aspirant
Nighthawk R7000 Offline, Needs Restarting DAILY!
Very frustrating, but ever since firmware update 1.0.11.126 in July 2021, this router goes offline pretty much daily. I can restart it using the app, and that process restores functionality, but in ...
- Oct 15, 2021
I also just called the internet utility and they suggested doing a factory reset. I'll keep you posted if anything changes.
Oct 15, 2021Guru - Experienced User
I would go back one prior version to 126 then.
Moongidget
Oct 15, 2021Aspirant
- FURRYe38Oct 15, 2021Guru - Experienced User
đ
- MoongidgetOct 24, 2021Aspirant
Just an update - After doing the factory reset last week, I have had 0 instances of the router being offline this week.
- FURRYe38Oct 24, 2021Guru - Experienced User
Enjoy. :smileywink:
