SteveM66
Aug 05, 2015Aspirant
Nighthawk r7000 Overnight Blocking
I'm trying to set up overnight blocking for a couple of my kids devices. I have assigned permanent IP addresses to those devices in the LAN configuration panel and set the timer from 11pm at night t...
- Aug 13, 2015I have too many other devices that connect to WiFi to have to turn it off for everyone and manually turn access on and off after setting up 2 profiles. Unfortunately until they have a better parental control panel, the only way to manage this apparently is by changing the time zone on the router by an hour and use the single window in the parental control panel for only the 2 devices I want to block. I'll have to adjust for DST and email time stamps will be off (I don't use that feature anyway).
Daenerys
Aug 05, 2015Luminary
Had the same problem before and what I did was I set 2 separate schedules. Since you want to block the access from 11PM to 4PM the following day, set the 1st schedule to 11PM-12MN and the 2nd schedule 12MN or 12:01AM-4PM for the following day.
Hope this will also work for you. :smileyhappy:
