SteveM66
Aug 05, 2015Aspirant
Nighthawk r7000 Overnight Blocking
I'm trying to set up overnight blocking for a couple of my kids devices. I have assigned permanent IP addresses to those devices in the LAN configuration panel and set the timer from 11pm at night t...
- Aug 13, 2015I have too many other devices that connect to WiFi to have to turn it off for everyone and manually turn access on and off after setting up 2 profiles. Unfortunately until they have a better parental control panel, the only way to manage this apparently is by changing the time zone on the router by an hour and use the single window in the parental control panel for only the 2 devices I want to block. I'll have to adjust for DST and email time stamps will be off (I don't use that feature anyway).
SteveM66
Aug 13, 2015Aspirant
