focu5dan
Feb 05, 2021Aspirant
Nighthawk R7000 overnight reboot
Hi all, i bought this router 2nd hand, and it has been fine but i have noticed that over night it has been rebooting at around 1am/2am for less than 10 seconds
this was while it was in Router Mode
i am now currently on AP mode as i am trying something new for my setup
just wondering if there is anything i can to stop it loosing connection each night ???
- JWS9518Luminary
Have you tried updating to the latest firmware which is currently .116, which, fingers crossed, has worked well for me so far, or downgrading to the firmware that has the reputation for being the most stable which is .42??
- focu5danAspirantMy current firmware is _10.2.100 Going to try the .116 firmware now
- JWS9518Luminary
If that doesn't help, I suggest going back to .42.. I don't personally like using old firmware, but it none of the newer firmwares work, it is about your only choice. I had to do that for a couple years until the recent .116 firmware.
