jjb2015
May 20, 2023Aspirant
Nighthawk R7000 power LED stays solid amber
Hi folks - hoping somebody out there can help me revive my old Nighthawk R7000 router. I've had it working flawlessly for years in regular router mode however today I tried to set it up in repeater ...
- May 21, 2023
Hi folks. Thanks for your replies. I did try the "recovery reset" option but that didn't seem to work either. However, what did work for me was the nmrpflash "Netgear Unbrick Utility". This can be found here: https://github.com/jclehner/nmrpflash
I run Arch Linux at home and nmrpflash can be found in the AUR, so it's a really easy install on Arch with "yay -S nmrpflash" ... and then follow the instructions in the github page linked above.
jjb2015
May 21, 2023Aspirant
May 21, 2023Guru - Experienced User
