fireblazin
Jun 26, 2017Aspirant
NIghtHawk R7000 PS4 Nat Type 2
Hello I had to do a factory reset due to log on issues. That is fixed however since the reset my son cant play Call Of Duty Black Ops 3. The PS4 says the NAT is moderate and it has to say its open t...
- Jun 29, 2017
Hi fireblazin,
Check for the port number for Call Of Duty and open it under port forwarding.
JamesGL
Jun 29, 2017NETGEAR Employee Retired
Hi fireblazin,
JamesGL
Jul 03, 2017NETGEAR Employee Retired
Hi fireblazin,
You can check as well under WAN setup for NAT filtering. You may change it to open.
- JamesGLJul 09, 2017NETGEAR Employee Retired
Hi fireblazin,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- JamesGLJul 10, 2017NETGEAR Employee Retired
Hi fireblazin,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
