Zxfyr
Jan 03, 2016Guide
NIghtHawk R7000 PS4 Nat Type Strict/3 Issues
I have always had a moderate at best NAT Type but when changing the place I recieve internet from the NAT Type has chosen to remain forever Strict. When changing my internet, the guy who did the chan...
- Jan 04, 2016
According to my ISP I cannot port forward due to the Dynamic IP they give me. They are charging a $10 price for a static IP. Is this something that happens? Port Forwarding unavailable on a Dynamic IP?
TheEther
Jan 03, 2016Guru
What is the brand and model # of your modem/router?
Do you have anything else plugged into the modem/router besides your R7000?
Zxfyr
Jan 03, 2016Guide
The brand is Phihong
Model Number is POE 16U 480
There are only 2 ports, one for the internet cable and one for the Router (r7000). On the box itself it says it is a single port injector and a switching power supply. Starting to think that I might have looked at the wrong things and this isn't actually a router
Nothing else is plugged in
- TheEtherJan 03, 2016Guru
That's not a router. That's Power over Ethernet (PoE) adapter. One of the wires from that adapter should lead to your modem/router.
Log onto your R7000 and go to the Internet page. The Gateway IP address is your modem/router. Try entering that address into your browser. This should connect to the modem/router. Unfortunately, you may need to find the modem/router to read the admin password off of the sticker.
- ZxfyrJan 04, 2016Guide
The router type is a Cambium Networks. Unfortunately the only place the router could be is on my roof and seeing as it is very dark out right now I will have to find the password tomorrow or contact my ISP. Thank you for all our help!
- TheEtherJan 04, 2016Guru
See if either of these combinations works:
Username: admin
Password: admin
Username: cambium
Password: cambium
