JJ77
May 04, 2016Tutor
Nighthawk R7000 Red LED on POE wired to IP CAMERA
Have the router wired out line into the POE unit LAN port and the camera wired line into the POE unit POE port. Everything works fine but the router wired LED is red?
- May 04, 2016
Searay, Thank You for the reply. I did read the whole manual. Maybe I am color blind, but the LED looks red!!! In an event I will assume the red is the new orange and everything is OK Also appreciate all replys!
Retired_Member
May 04, 2016It's orange meaning 10 100, read the manual
