JJ77
May 04, 2016Tutor
Nighthawk R7000 Red LED on POE wired to IP CAMERA
Have the router wired out line into the POE unit LAN port and the camera wired line into the POE unit POE port. Everything works fine but the router wired LED is red?
- May 04, 2016
Searay, Thank You for the reply. I did read the whole manual. Maybe I am color blind, but the LED looks red!!! In an event I will assume the red is the new orange and everything is OK Also appreciate all replys!
VE6CGX
May 04, 2016Master
Red or Orange? If red I have no idea. If orange it is running at 100mbps max. speed. Not at 1Gbps . Maybe your camera LAN is
100mbps port
- JJ77May 04, 2016Tutor
