JJ77's avatar
JJ77
Tutor
May 04, 2016
Nighthawk R7000 Red LED on POE wired to IP CAMERA
Have the router wired out line into the POE unit LAN port and the camera wired line into the POE unit POE port. Everything works fine but the router wired LED is red?
  • JJ77's avatar
    JJ77
    May 04, 2016
    Searay, Thank You for the reply. I did read the whole manual. Maybe I am color blind, but the LED looks red!!! In an  event I will assume the red is the new orange and everything is OK  Also appreciate all replys!
