JJ77
May 04, 2016Tutor
Nighthawk R7000 Red LED on POE wired to IP CAMERA
Have the router wired out line into the POE unit LAN port and the camera wired line into the POE unit POE port. Everything works fine but the router wired LED is red?
- May 04, 2016
Searay, Thank You for the reply. I did read the whole manual. Maybe I am color blind, but the LED looks red!!! In an event I will assume the red is the new orange and everything is OK Also appreciate all replys!
Mars Mug
May 05, 2016Virtuoso
The POE device is unlikely to do anything other than apply power to the appropriate lines, so is unlikely to affect the Link Rate. IP Cameras commonly operate at 100 Mbps, there is typically no need for the bandwidth that gigabit rates would provide.
JJ77
May 05, 2016Tutor
Really appreciate the response. I did find my room overhead LED lighting made the orange router LED look red. Turning off the room light made the router light orange.. Really liking this router vs the Belkin N900 it replaced.
